it keeps saying its in use by an application, i have no applications installed, i dont know how to format it now.
helpl n80 wont let me format memory card!
Do a first format in a card reader.
i dont have a card reader, i ended up putting the minisd in my audiofox smt5600 and connecting to pc, and just deleting everything, then i finally was able to format on the n80
Your "audiovox smt5600" is a card reader, or had acts like one. Case solved!
I am getting this problem a lot too. I think it comes from when data on the memory card is used by the phone, for example if you have an image on the memory card as you phone's background, it doesn't like it. I keep getting this error with other things like when choosing 'data transfer' with USB cable, even when no other apps or backgrounds or anything are active. I think another bug may have cropped up.
Could be. Also the Themes, cause a lot of problems,
i had this too, i restarted and it worked ok 😊
Jaffa cake - love the name!
I think best to keep apps etc that are in use, like full screen caller, active themes, backgrounds etc stored on phone memory
help please i am having the same problem, please try to solve it or tell me how to format the memory card.
pinksteady wrote:Jaffa cake - love the name!I think best to keep apps etc that are in use, like full screen caller, active themes, backgrounds etc stored on phone memory
Is not really necessary, with most of phones. Usually they work well. The only one who causes preoblems is N91, but it have an HDD, and the things doesn't work exactly like on others.
ive also encountered this problem i almost planned on buying an adapter for the mini sd but then in the end i have formatted my card using my N80
all ive done is i
-restarted the phone
-after going to idle screen the "installing" dialog box will appear
-hold down the menu button to display running apps in the background
-select the "installing application" then press "c" to stop the tunning background
-this should stop the applications that run from the memory card after that you could now format your memory card with the n80.
i dunno if this works for you guys but it did really work for me
heres the firmware of my phone
V3.0617.0.6
03-05-2006
RM-92
Nokia N80 (11)
