Screen loose on N80??
4 replies · 1,587 views · Started 19 August 2006
Hi all,
Just got my brand new N80 and I think its great so far, but I've noticed that the front half (silver half) of the handset is slighty loose against the back half of the handset, as if they rotate against each other slightly. I'm only talking less than a millimetre movement but its a bit of a niggle. Just wondered if anyone else has encountered this, and if its just a 'character' that the phone has?? I've just seen two of my friend's new nokia slide phones, and they appear to do something the same. Any comments would be appreciated!
Cheers,
Simon
Mine was quite tight when it was new but now it has loosened up a bit. Probably par for the course and its only wear and tear - nothing you can do about it. I shouldn't be too concerned.
I don�t have an N80. But your problem, well, is not a problem, as far I had read. It happens a lot. Do a search is this forum and You find a lot o others with same thing...
Yeah the screen on my N80 has a little bit of play in it as well. My 7650 was a lot more rigid as I remeber. I'm not convinced the N80 has as good build quality as other Nokia's I've owned (I mean what's the deal with memory card door?). In answer to your question, I think they're all just like that.
Thanks for the help guys, put my mind at rest a bit! Like I say, its more of a niggle than anything else, but I suppose I can live with it. Cheers again.
