:tongue: Ok, ive been a little off but here i am, here is the info 😃 hope it helps, BTW version v40623.0.41 its pretty cool
Change in this version :This version of fimrware supports FOTA (Firmware Over The Air) in some variants.
Improvements from v3.0617.0.6 to v40623.0.41
Backup
* Backup cannot read midlet when midlet is running before backup starts
* Contacts database is in use if client remains open duringbackup/restore
* Java midlet data is not restored
* Panics if java hash information was not parsed successfully
* SIS files are not restored after backup/restore
* Midlets installed to drive other than (C not backed up or restored
* Package data file restoration problem when directory doesn't alreadyexist
* Backup/Restore failed to restore assigned Speed Dial numbers
Bluetooth
* Improvements to stability of long term connections
* Switching on BT On >off> on can cause phone menu to lock up and disappear
Browser
* Browser memory usage reduction when browsing many sites
* WAP Push correction for CSL
* Remove anti-aliasing for Chinese fonts
* www.kauppalehti.fi login causes connection timed out
* Stop browser loading images when memory low
Calendar
* Meeting end date does not span correctly if user changes device timezone to greater than current value
* Received recurring vCal entry is not saved to calendar
* Calendar alarm time imported incorrectly from S40 device
* Calendar editor erases subject field if you edit a full subject field
* Calendar crashes when changing repeat rule on an entry
* The anniversary alarm never goes off
* 100 consecutive alarms does not alert
* Due date and start date are mixed in ToDo items > ToDo alarm can not be stopped
* Calendar Options>Delete entry>All entries fails to delete exceptions to recurring meetings.
* Change in time zone results in incorrect alarm date.
* System error and product freezes with certain Calendar note
* Lunar Calendar information is not available for dates before 1980
* Last instance of repeating meeting is lost, if repeating meeting is modified in Outlook
* Unable to dismiss calendar alarm
* Repeating calendar entries
Call
* Manual network selection freezes the phone if there is active PDP context
* Display wrong operator name "1" in Manual Selection list
Camera
* Bitmap corruption in thumbnails
* Camera localisation error fix (Localised Slovak) Camera: Wrong grammar form of Automatic used in Scene Set-up
Contacts
* Backslash character not properly handled when contact is copied to memory card
Data
* Call Back Access Point does not call back
* Rare Stability problems in TCP/IP
Device Manager
* Display FOTA help for FOTA enabled variants
Gallery
* Certain animated Gif files do not play when opened from Images and Videos folder
* Screen becomes black for a second right after playing video file saved in memory card
* Wrong Presentation icon is shown in the Gallery.
* BT Image Print Phone is stuck at Cancelling screen
* PictBridge/HP475 Phone hangs at cancelling screen after cancelling a pictbridge print job on HP475 printer
* Video file is not played if opening from File Manager while another is paused on the background.
* DRM image can't be zoomed in if the last right is in use.
* The display position of AnimatedGIF file is incorrect.
* New Camera Images do not appear in Gallery if Gallery is open
* The Animated GIF file, which has copyright protection of valid Consumable Rights(count=5) can be played more than 5 times.
* 3gp playback incorrect when there are many images on memory card
* No help topics available in Music Settings View.
* Issues with recognizing new mimetypes
* Localisation
* Fallback when help directory is empty
* Memory Card
* Improve FAT mount performance by increasing FAT cache granularity
* Particular 256MB MiniSD card gives "Windows was unable to complete the format" when formatting under WinXP.
* Memory card unlocking does not work if no card inserted while phone booted
* Fix for memory card missing on soft reset
Messaging
* Forwarded attachments visible as unsupported files in attachments view
* Envelope icon doesn't stop blinking until phone is rebooted
* E-mail : It takes too long to attach contacts via e-mail.
* Message stays in outbox (until rebooted) after cancelling infrared transmission
* Fixes MMS postcard image import size issue
* Obex crash with corrupted obex header
* Extra space at end of word when typing '/' character
* Can't receive message when using China Unicon dual mode card
* Add any file type to email attachment options
* Incorrect number is shown in note when fetching emails
* IMAP: Crash after trying to retrieve an email when there's no network coverage
* Message Viewer takes 39 seconds to display long unicode message
* Link Highlight in automatic find does not wrap to next line in mixed URL/number
* Data cannot be shown and deleted when save a large vCard which received by IrDA.
Multimedia
* Progressive JPEG codec doesn't compress heap after decoding
Music Player
* Music player will be terminated forcefully at the time of selecting searched data when the [Mark all] selected in track list creation.
Networking
* Sending many UDP packets results in not all packets reaching the recipient.
Real Player
* Large chunk video break up
* Unresponsive RealPlayer after streaming
Security
RM-92_EMEA_PR_dp_v13.00_SW4.0623.0.41.rar
* No post after user cancel JAR download
* Exes are launched by Installer App before EULA is accepted
* Installer crashes when uninstalling software
* App. installed in other phone to memory card, shortcut to it is shown in test phone
* Reset loop with certain (filesystem partly corrupted) MiniSD card
* Application Manager: Application loses list of installed applications
Syncronisation
* Session ID in server notification (package #0) is not taken into use by DM client
* Synchronisation fails if entering more than 2 entries in Calendar of the handset with synchronisation setting as "None"
UPnP
* Unknown authorisation request causes media server crash.
* UPnP Apps Menu path in message for creating WLAN access points is incorrect localisation of path for all languages.
* Middle ok button does not work in result window
* Copying files with �&� character in
* Home Network, fix for Music playlist sharing selections not working
USB
* Mass Storage failure. Bulk Transport handles case badly
* USB mass storage class doesn't detach from Apple MAC/Tiger
Video Telephony
* UE carried no sound or image after the following procedure UE became out-of-coverage during VT communication. Then it originated
* VT after the VT disconnection.
* The following changes were also included in SW release 3.0618.0.1 which was only available in some markets.
Call
* DTMF tones now allowed for emergency call created with locked phone
Applications
* RealPlayer updated � Improved handling for large chunk video break up
* RealPlayer updated � Improvements to unresponsive RealPlayer after streaming
Settings
* Settings wizard updated to week 16 release for Taiwan country Settings
SIM
* Correction to SAT polling reponse
* Accessories
* Connecting doesn't succeed after disconnecting N616 car kit and from 3G to 2G
* AD15 in Music Player mode has poor sound quality (until volume changed)
Dx do it again lol :tongue:
cheers
Dx
