plz ,,i have nokia 6630 and the battery remains for only 2 days is this normal or there is a problem,,,,
N.B.
i have changed the battery once and the same happened
battery life
Du you have any viruses on your phone? Are you using the phone at it's limit? You talk too much? Give some details...
Change the phone from 3G to GSM, if You don�t use it a lot. Then, see the difference.
it's normal
thanks ,,
i use the phone at its limits ,,,i checked for viruses but there are any,,,
u can say i do not use the phone at all,
i changed the phone yesterday and the same happens ,,,another thing i can see horizontal lines in the screen ..i saw it once and didn't come back
i am collector ,,,,but i changed the nickname
