Is it safe to use nokia car charger?
4 replies · 2,664 views · Started 21 August 2006
Is it safe to use nokia car charger? Since the car charger is using electricity from the car battery; not common electricity such as from a power socket.
Will it shorten the life of my battery if I use the nokia car charger often?
-riannn
Is not so good to charge like a Home charger. A car produces alternate corrent, with pick corrent not exactly the same. A battery could be damaged by that, and life became shorter. Use only for emergency and not for usual use.
nj7 wrote:Is not so good to charge like a Home charger. A car produces alternate corrent, with pick corrent not exactly the same. A battery could be damaged by that, and life became shorter. Use only for emergency and not for usual use.
Noted, use it as emergency only...
-riannn
If the Nokia car charger (like the AC adapter) provides the correct voltage then there is no difference.
E61DRC wrote:If the Nokia car charger (like the AC adapter) provides the correct voltage then there is no difference.
Well shouldn't it? by default... its the original nokia charge...
-riannn
