'Installation not supported' message
7 replies · 8,285 views · Started 21 August 2006
I have a new N80 an cannot install any applications. I get an error message: 'Installation [name] not supported' message.
Any help or ideas?
Firmware is v3.0617.06 03-05-2006 RM-92 Nokia N80 (31.01)
Thanks, Micheal
The software are S60 v3 compatible? The old software, S60 v2 don�t work on N80!
On Aplication Gestion, You change the permission of installation of software for "Yes" and Check Cert. On-line, to "No"?
The items you want are located in the Settings Menu of the Application Manager (labeled App. Mgr. in English versions of the N80) you can find that in the tools menu.
British version may be slightly different but for Software Installtion the options are: Signed only or All. The dafault is ALL and for Online Certif. Check the options are: Must be passed, On or Off. The default is OFF. However, it still does not work.
You have the correct options, and use of S60 v3 version... That happens after some installation? The last one? Remove that last one. Try again.
