How to clear the operator logo on 3rd Edition S60!
4 replies · 7,013 views · Started 21 August 2006
Now it is possible to "clear" the operator logo of all the latest Nokia mobiles (e.g. N80, N73, N71, N93, N91 ..) as well as E-Series.
Example
Download
Instruction:
Install the little java program. Maybe you have to choose your internet accesspoint. Then enter your own mobile number in the upper field. Choose your provider, then choose OK. You'll then get a SMS containing the "clear" operator logo. Open the SMS and save.
You're done.
Hello dragon i want to clear my operator logo but i dont understand you clear exactly what i must to do?
from where to get this litle java application and etc can you explain me again please how to clear the operator logo
thanks!
ok this is what i did:
1. Installed program
2. Opened Program
3. Typed in my # at the top
4. Selected Tmobile
5. Got my Message, Opened, & Saved
6. It asked "Clear All Operator Logos" , Clicked Yes.
The T-mobile Logo... is still on my N80
Whjat did I do wrong?
You probably did nothing wrong. The operator may have locked/prevented changing of operator logos (i.e., it is fixed in that operator version). One more reason to stay away from operator branded devices.
