do u want to remove ur op-logo? go here http://nologo.sourceforge.net/ota1.php select ur country, it then gives u a link, open the link in ur fones brouser to download and install the small app, open the app put the number of the mobile u want to delete the logo off, select the network then press options, ok! thats it, wen ur logo arrives just save it! also i did it with my n80 and now in settings/phone settings/display the op logo menu is ther so u can turn logo on and off! enjoy
get rid of ur op-logo
Biggzy wrote:do u want to remove ur op-logo? go here http://nologo.sourceforge.net/ota1.php select ur country, it then gives u a link, open the link in ur fones brouser to download and install the small app, open the app put the number of the mobile u want to delete the logo off, select the network then press options, ok! thats it, wen ur logo arrives just save it! also i did it with my n80 and now in settings/phone settings/display the op logo menu is ther so u can turn logo on and off! enjoy
hello mate,
nice one, cheers for that, as a seperate point have you upgraded your firmware, i'm in 2 minds at the mo as it doesn't seem that worth while looking at the feedback in some of these forums
cheers
Dean
alrite pal, yes iv updated my FW to v4.xxxx and its very good, my n80 is working like a charm, theres just 1 small bug, check out the n80 bugs post to c what i mean, other than that i think its well worth the update!
Biggzy wrote:alrite pal, yes iv updated my FW to v4.xxxx and its very good, my n80 is working like a charm, theres just 1 small bug, check out the n80 bugs post to c what i mean, other than that i think its well worth the update!
ok buddy, i will take ur word for it...off on hols on wed so will leave till i get back i reckon...just incase i knacker it up!!!!
hey i try goto to that site using my n80 but it says no content are you sure that is the right link???:frown:
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (4.0623.0.22) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
yes the link is corect, u may need pc or use the n80s WEB browser not SERVICES!
thanks - it works a charm!
Biggzy wrote:Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (4.0623.0.22) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)yes the link is corect, u may need pc or use the n80s WEB browser not SERVICES!
You sure this works on previous firmware? I'm on v3.0617.0.6 and I can't get the link to work (and yes I'm using the web browser), and even when I got the link to the app from the jagden.php it installed fine but does nothing when you try to run it (when installed on the card or in the phone memory). :frown:
i tried to do something smart i downloaded jadgen.php then i toke the addres and i downloaded the nologo.jar (thru my PC) and i installed it on my n80 but nothing happened ,why ?
u cant download with pc then transfer to fone as it wont work, and yes it works on all the FW versions!
i download and install it but the thing is when i open in my message inbox it says delete all operator logo .. but nothing happen my operator logo is still there.. can u help me how to use this...thanks
