Mines started taking about 20 seconds to send a message now, sometimes longer. I dont just mean for the little outgoing arrow to dissapear either, I'm talking about the progress bar that shows up after hitting send
Does the new v4 firmware stop the slow text messaging?
Mine is a lot better now but that may be because it was wiped, which seems to be a temporary cure for it, so its a bit too soon to tell.
Lets wait couple of weeks and lets state it here.. mine is fine, lightning fast. I HOPE THIS PROBLEM WONT COME BACK.
Mine sends texts very fast now, instantanious.
tomnufc wrote:Mines started taking about 20 seconds to send a message now, sometimes longer. I dont just mean for the little outgoing arrow to dissapear either, I'm talking about the progress bar that shows up after hitting send
You still have problem with freezing while sending sms message? You're in V4?
Download the SMS accelerater
It should help:redface: 😉
hippo1n2 wrote:Download the SMS acceleraterDude, this thread is over 6 months old, I'm sure they all got the SMS accelerator long ago. 😉
S.
