outgoing call is perfect,,,whereas incoming call have to re-adjust the handfree volume when is connect ,,,this is really unsound for N80,,,any solution ????
any problem for N80 bluetooth?....need advise ,,
The latest firmware has some bluetooth changes included.
Check your current firmware (using the *#0000# code) - if it's less than v4.0623.0.41 I'd suggest you start by upgrading the firmware. This can be done under warranty at your local Nokia Service Centre (use Nokia's store locator to find your nearest) or if you're comfortable with doing it yourself you can follow the instructions in the large firmware thread on this forum.
Agree. To do the upgrade - maybe wait a little and do by Nokia Site, now is possible (not for N80, today).
silky wrote:outgoing call is perfect,,,whereas incoming call have to re-adjust the handfree volume when is connect ,,,this is really unsound for N80,,,any solution ????any problem for N80 bluetooth?....need advise ,,
That's something to do with N80 being not compatible with general BT Headset on the market. See this thread http://discussions.europe.nokia.com...scending&page=1
my current fw is 3.0617.0.6 3-5-2006 rm92,,,
i know new fw4 version is release,,however our local nokia sc told me 3.0617.0.6 were current firmware wht they have....
used to visit nokia.dotoe.com for DIY upgrade,,,but untill now i still can complish down 105mb fw4 and other software such as phoenix 2004,,
any suggestion,,??
silky wrote:.
i know new fw4 version is release,,however our local nokia sc told me 3.0617.0.6 were current firmware wht they have....used to visit nokia.dotoe.com for DIY upgrade,,,but untill now i still can complish down 105mb fw4 and other software such as phoenix 2004,,
any suggestion,,??
The firmware's roll out across service centres is staggered - only 1 of 4 centres in my area knew about the new firmware. That's why I flashed my own. If you have other service centres within reach then ring round to find one with the new files, otherwise chase up your local service centre and find out when they will get the update (shouldn't be more than a couple of weeks I would think).
