Hi, if i upgrade to the v4 firmware and all goes wrong can the nearest nokia service center still correct the problem and fix the phone ok ? Just thought would ask as not sure what to do if all goes wrong !!
Brian
Brian
readbmr wrote:Hi, if i upgrade to the v4 firmware and all goes wrong can the nearest nokia service center still correct the problem and fix the phone ok ? Just thought would ask as not sure what to do if all goes wrong !!Brian
If it all goes wrong, tell them (Nokia Service Centre or your Network Provider) the handset just stopped working - do not admit to self-flashing as it is highly likely to invalidate your warranty.
Having said that, just make sure your battery is fully charged and remove the SIM CARD, then there's not much chance of the Flash stopping part way through.
Hope this helps.
Thankyou and many thanx for that, think i will try and flash the phone to-nite, just also want to make sure its the UK GENERIC VERSION, V4 Again many thanx for your help.
Brian
