Realplayer files on E61
5 replies · 4,936 views · Started 22 August 2006
Wirelessly posted (Nokia E61: Mozilla/5.0 (SymbianOS/9.1; U; en-us) AppleWebKit/413 (KHTML, like Gecko) Safari/413)
Take a look at the Super and Smartmovie discussions in several forums (fora ?) Both should do the job.
Regards, Michael
you should convert your real video to 3GP format, i think
.rm format is not so popular now . you may try Xilisoft video converter 3.1.
you may trial version to make sure whether xilisoft support rm format or not.
Krisse - your best bet is converting into MP4 format with the H263 codec. As someone else mentioned SUPER should be able to do this. I haven't actually check rv conversion. If you can;t get anywhere let me know and I'll look into it in more detail.
It strange because I though RV 10 were supported.
Thanks for all the help, I'll try these suggestions!
"It strange because I though RV 10 were supported."
Yes, that's what I thought too, that's why I'm posting about it on here! 😊 As I said, the sound worked fine, and the file downloaded fine, but the player gave an error message and no picture.
