Connecting to the N-Gage through Bluetooth
3 replies · 1,263 views · Started 22 August 2006
Hello...I'm new here...
Anyway, I got a bluetooth dongle today, and have got it connected to my N-Gage. Problem is, I can only connect through PC Suite. I don't wanna do that, because I want to access the hidden System folder. How can I access the MMC card through windows explorer?
It's probably quite simple, but I'm out of ideas...
Withouth bluetooth. If is N-Gage (original) connect by usb mass storage, and do what you want to do with the card.
That's fairly useless, but thanks anyway...
It's a QD (if that makes any difference) and I don't have a data cable, hence the reason for asking about bluetooth...
Well, You don�t said that in beginning. If is a QD, then, the only way to connect the QD to a PC is by bluetooth. But, by bluetooth, and PCSuite for N-Gage QD, You can�t touch the system files. The ONLY way, in that case, is removing the card, put on card reader, and with Windows Explorer, You can do what You want to do.
