Nokia Software Updater!
1 replies · 12,230 views · Started 22 August 2006
Nokia has released a software named 'Nokia Software Updater' which helps to update the phone's software and firmware by downloading the updates to pc and installing via the data cable. The software and update packages are provided by nokia free of cost so that people can keep their phones updated and don't need to go to the centres to get their firmwares updated! This software helps update the firmware which has improvements/fixes for the phone. This software can be downloaded here:-
http://www.nokia.co.uk/nokia/0,1522,,00.html?orig=/softwareupdate
The currently supported phones are:-
Nokia N70
Nokia N72
Nokia 6131
Nokia 6630
Nokia 6680
Nokia 6681
Nokia 6682
You should keep your phone updated and check once or twice a month for updates in the firmware which might fix some issues. Happy Updating!
I just updated my firmware! Everything Worked flawlessly!
