Hi, have searched through a bit and can't find this. Is there any way to change the settings so that your "to-do's" display on the main screen of the N70? By default, it displays one, but if you have more than one it just says "2 to-do notes not completed". I use to-do's much more than calendar, and would like to be able to see them all at a glance.
pashabear
To-Do's on screen (N70)
Menu - Tools - Definitions - Phone - Stand by mode - Selection button - change - Go to, or active stand by screen.
Hmmm... My N70 has no menu or submenu option DEFINITIONS. The manual doesn't mention it either.. Would be cool to be able to better personalise the ACTIVE STANDBY screen though
What kind of N70 do You have? No definitons? How do You personalize the phone, the screen, the connections, Hour, etc? My N70 have...
nj7 wrote:What kind of N70 do You have? No definitons? How do You personalize the phone, the screen, the connections, Hour, etc? My N70 have...
That's because you mean SETTINGS not Definitions!
And in any case, the question from Pashabear was how can he display all his to-dos on screen, not just a summary - he's clearly got active standby in operation.
And the answer is, you can't. With only one To Do, you get the its name, with more than one you get a summary.
With calendar, only the current day's appointments are shown, and if none for that day, anything in the next week is displayed.
I do the direct tradution from my menu language, and the tradution is "Definitions"... A lot of languages..., and I never ever saw a screen in english. Thats it!
