Question..about..nokia N80 Wifi
6 replies · 9,477 views · Started 23 August 2006
i have heard that nokia n80 has a Integrated Wireless LAN (802.11g).
i have checked some places in leicestershire that have wifi slots and they say they are.......802.11b Wi-Fi .
ok my question is if i buy a nokia n80, can i a use the hot intergrated wifi in my n80 in a place that supports 802.11b Wi-Fi ..
or is this wifi thing a waste of time in phones, i thought when i go out to pubs and cafes i can use my phone and not carry my laptop. please help
heres a wifi hotspot address of places in leicester most are free..
h**p://ipass.jiwire.com/search-wifi-hotspots-parametric.htm?pay_free=both&technology_id=0&city_id=2131043&location_type_id=0&type=parametric&&startnum=1
i dont want to waste two weeks wages on a something thats not going to do wifi out side of the house, ie .......pubs, bars, cafes
please help
THANK YOU IN ADVANCE
The phone is compatible with 802.11b networks.
Are these hotspots paidfor services or open networks?, I do not need to use paidfor networks but have successfully connected to open networks and sent/received email,voip,surfed,streamed media.
ok, well i use my laptop on some of these sites in the web address and most are free.
i wanted to know if i bought the n80 will i be able to use 802.11b Wi-Fi connections, as the nokia site only says....802.11g.
does the n80 have a feature that you can change from a setting of ...802.11g Wi-Fi to 802.11b Wi-Fi, option on it, that would be great. so if some one can verify that please DO.
N80 is 802.11g so it will not work with 802.11b, I tried to connect at starbucks that has 802.11b 11Mbs and it didn't work.
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (4.0623.0.22) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
same ere, i use g at home and b at my parents, works fine!
