P990i Selfmade Root certificate Problem
0 replies · 6,096 views · Started 24 August 2006
Afther googling a whole day, I hope that somebody can help me.
I try to put an selfmade SSL root certificate on my P990i.
steps:
1. export the certificate from Internet Explorer to DER-format
2. The device don't recognise the file. (Not supported)
3. convert the file from DER to PEM with openssl.
4. The device recognise the file but opens it with Quickword.
I've put the file on the device via USB, BT, browser. Always the same problem.
The device recognise the certificate as a text file, tried with extensions .cer .der .crt .pfx .pem
Does anyone knows the solution.
Many thanks in advance.
Wim
