Updated my UK Orange N70 using the nokia.co.uk/softwareupdate updater last night. The new firmware allows me to turn the stupid Orange sidebar off.
However, it comes back seemingly at random. Often, if I install software - I just installed PC Suite support on the phone, and when I finished the installation, the sidebar was back. Aaargh!
Anyone else been seeing this problem?
I've found it comes back when I do a reboot of the phone (Battery out),
Carl,
No issues here, turned the OHS off once I got the upgrade and it's stayed off ever since.
S.
No issues here neither, wierd problem :con?
This is doing my head in. I turned the phone on this morning and the sidebar was back. So I switched it off and the phone restarted. Then I connected it to the PC, and when I disconnected it the bloody sidebar was back!
AAARGH 😡
If you switch the phone off then on again the sidebar WILL return,
Carl,
CJackel492 wrote:If you switch the phone off then on again the sidebar WILL return,Carl,
Err, nope, I've power cycled my handset numerous times and the Orange Homescreen remains firmly switched off. I've even had the battery out too.
S.
steve_perry wrote:Err, nope, I've power cycled my handset numerous times and the Orange Homescreen remains firmly switched off. I've even had the battery out too. S.
Which firmware version do you have and which phone?
Mines N70 V5.0616.2.0.3
Carl,
CJackel492 wrote:Which firmware version do you have and which phone?Mines N70 V5.0616.2.0.3
Carl,
I've got the same version, V5.0616.2.0.3 Orange variant firmware.
However, I haven't used PC Suite to connect to or backup the phone.
S.
