hi does anyone have an idea what is best the N80 or the N73
thanks
pete
thanks
pete
Depends... What You wan�t?
N73 - better Battery, Camera;
N80 - Wi-Fi;
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (4.0623.0.22) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
i have both n73 and n80, in terms of featurs the n80 blows n73 away but n73s camera is great, also the screen is about 1 cm taler than n80 but it aint a patch on n80s hi rez, if i had to pic between the 2 id go for the n80 anyday, i use wi-fi alot and n80 is nice and small and the screen is great wen using the web, also i use the upnp and stream music frm my n80 to my pc!
not used the n73 but when i use my 6680 the screen looks crap compared to my n80 😊
Jaffa-cake wrote:not used the n73 but when i use my 6680 the screen looks crap compared to my n80 😊
Between 6680 and N80, of course! But between N73 and N80, I like more N73, because is bigger! Is a great display.
n73 screen aint as bad as 6680 etc, its quite gud but just dnt live upto n80s!
Biggzy wrote:Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (4.0623.0.22) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)n73 screen aint as bad as 6680 etc, its quite gud but just dnt live upto n80s!
Bigger, but.. with less resolution!
yes less rez than n80s screen but it has more pixels than 6680 etc, shame n73 didnt have n80s screen! also wifi wud b nice in n73!
N73 is the best.The screen is large and probably will have more 3rd party applications made just for it.
N73 isnt as good as the N80. Only thing N73 has going for it is the slightly better camera. N93 is a better choice than the N73.
fdxd wrote:N73 isnt as good as the N80. Only thing N73 has going for it is the slightly better camera. N93 is a better choice than the N73.
I don't think that you can really compare the N73 and the N93. The N93 is a massive, heavy and very expensive phone. The N73 on the other side is much sleeker, lighter and cheaper. Both phones are intended to a very different audience. If i had to choose between the 3 of them, i would go for the N73 for it's look and it's large screen which should give more screen real estate to the applications than the N80 despite the lesser resolution. Shame that it doesn't have wifi though.
yeh if n73 had wifi it wud b v good
Peterm wrote:hi does anyone have an idea what is best the N80 or the N73thanks
pete
Kinda pointless discussion which often leads to bad feeling and argument...
:tongue:
However, it's a simple choice...
Need or Want WI-FI? then get the N80.
Otherwise get the less expensive N73.
Dez 😎
dez_borders wrote:Kinda pointless discussion which often leads to bad feeling and argument...
:tongue:However, it's a simple choice...
Dez 😎
Agree... Like I said in the beginning.
Personally I like the N80... I dont like the look of the N73 at all. I look at features & the look of it as the whole package.. if Im not happy with either one, I wont even look twice at the phone. I did that with the N70, went for features and didnt like the look of it... I replaced it within 6 months 😃
