Firmware update on 6630
6 replies · 3,969 views · Started 24 August 2006
Hi, I'm using a Nokia 6630 on Orange UK, if I update my system software from the Nokia site, will it get rid of the Orange screen thing?
Ok. Will it eveng ive me an option to turn it off?
Also, do you recommend updating? :redface:
That kind of things are in ROM, so can�t be turn off. Is live with that. Do an upgrade, always. Usually improves the stability, the operation is faster, and add little things. So do the upgrade.
Even better! So your 6630 is up to date. So profit that, because in terms of firmware, nothing to do😉
