Hi, I'm having difficulty trying to get e-mails sent from my laptop out through my 6680.
I have the lead and bluetooth but the settings are too difficult for me to understand.
Can anyone put them into logical order and in plain easy understandable terms please.
Connecting Laptop to 6680
It's pretty easy. Install Nokia PC Suite on the laptop. Use the "Get Connected" wizard to set up the USB connection, Only plug the phone in when it tells you to!
Once you've got that setup and it says "Nokia 6680 connected via USB" then you should open up pc suite and click connect to the internet. Click the settings button and use the wizard to select your mobile operator. Once that is done you should be able to connect to the internet through your phone on your laptop and send e-mails without a problem.
Many thanks simon for the guide.
