I just tried to update my firmware on my Nokia 6682 Cingular branded and it said that the upgrade failed. Now my phone wont even turn on, even when i plug in the charger there is no sign of the phone being able to turn on. Can anyone help?
6682 firmware upgrade help!!!
Could You retry again? If not, remove the battery for a long period > 1 hour, and try a software upgrade again! Not sure if it works. The last way, is always go o a Nokia Sevice Point.
Was your phone unlocked? did the shut off for long time worked?
