Hi, i just bought a nokia n80 a few days ago, everything works fine but it freezes quite often, either it takes a long time to load a screen, or somtimes it just goes blank and the nokia logo pops up for a while then slowing the screen loads back up. Is this a common issue with the software? what can be done about it? thanks
nokia freezing and slow load
This behavior is normal on all S60 phones. The way to minimize, is do the firmwares upgrades, check if you have the last one.
