Need Older versions( below 1.98.8.2) of the sendo X firmwares!please
2 replies · 5,353 views · Started 27 August 2006
@ALL
as per the above subject, i need some firmwares like 1.160.7.2 for sendo X, i would appreciate if you share any version of the firmware with me. PLEASE.
WBR
ReyTech.
:con?
As posted elsewhere, all firmwares prior to 1.198.8.2 are SPN locked, so you need the correct firmware for your phone. (for example, an Expansys firmware won't work on a Vodafone branded phone)
stuclark wrote:As posted elsewhere, all firmwares prior to 1.198.8.2 are SPN locked, so you need the correct firmware for your phone. (for example, an Expansys firmware won't work on a Vodafone branded phone)
@Stuclark
Thanks for your rely, can u please tell me that my phones might get rectified if i try flashing all the available firmwares of 1.198.8.2? or shall i try flashing anyother older firmwares? and can u post a link here from where i can download the older firmwares?
WBR
ReyTech.
:con?
