E70 - conecting with WLAN for voip
1 replies · 3,177 views · Started 27 August 2006
Hello,
I have nokia e70 and i'm trying to connect to sip proxy server but i can't
The reason is that i cannot connect to WLAN by making voip call.
I'm connecting with WLAN when i run browser or getting emails.
Is there way to connect my phone to WLAN without running browser or email client, and make e70 used this connection for voip calls ?
maybe this is a bug my software version is :
1.0610.05.07
30-05-06
RM-10
Did someone successfully get voip calls with WLAN on this software version ?
Please HELP !
Best Regards
Slawomir Swider
You need to upgrade your firmware.
I had the same problem and after upgrade there was extra options in the connnection menu's.
ow I have it working very smoothly, so that when I'am at home the Sip is permi nantly registered, wifi is also perminantly connected.
Any incoming VOIP calls ring my mobile straight away.
The only bug is the recorder will not work with voip calls.
