E61: Special Ringtone for Internet calls?
2 replies · 2,687 views · Started 28 August 2006
I own an E61 and use VoIP with good success. The only thing that bugs me is that Internet Calls have the same Ringtone as regular Calls. Is there a config option where I can set a special Ringtone for Internet Calls?
Cheers,
THEPO
Only, if the calls to You came from a difined numbers, and You can create a Group for them. Another way, without a dedicated software, don�t seem possible.
I am curious, because so many posts all over the interenet are full of people struggling to set up the Nokia to make internet calls. Is there a special router that you can buy that enables SIP calling or do you have to have a special server for VOIP running on your side of the firewall? 😊
