can someone please post links of video converters for N70 that are full version or with serials
i have trouble in finding them
also link of smart movie player or any player that supports all possible formats videos
also what specifications i should keep while converting a video to be played on N70 for the best quality even in full screen
which codec is the best
what audio quality should be there
please help guys
thanks in advance .....
bye:icon14:
eRightSoft Super works well for me and has the added advantage that it will also convert video for e.g. PSP and iPod video.
Try these settings for the N70:
3GP Nokia, etc. / MPEG4 / AAC / Direct Show off / 220x176 (352x588 works but wasted on the lower resolution screen and bigger files, etc.) / 15fps for NTSC (30fps/60hz) or 12.5fps for PAL (25fps/50hz) source material / 480kbps / hi-quality / 22050 / 2 / 48 / default
Also check out www.youtubex.com to download Youtube videos (then convert - Super works with the saved .flv format)
thank a lot friends
thank you:icon14: 😊
