Recently installed the themes that came with the Nokia PC Software and right now I am having some trouble finding how to uninstall those themes, saved it on my 2gb MiniSD and I couldn't seem to find the themes from the Tools>Application Manager menu. Is this one of the known bugs for the N73?
Uninstalling Themes from N73
its not a bug i guess... installed themes which were saved in the memory card is placed in a hidden folder which can only be accessed through a pc.... connect your phone to a pc then select mass storage, then access the private folder (F😛rivate (I guess)... you'll find a folder were all the themes are located, each theme is located in a separate sub-folder the folder will have 3 files each....most of the themes will have a file name that ends with a .mbm..... just delete the all three... you'll just have difficulties in identifying which theme, coz most of the themes doesnt have a name just numbers or letters.....
