Stupidly, before flashing my firmware to the latest V4, i forgot to back up all my contacts to the memory card, thus loosing them. The number for my voicemail box has also dissapeared, and i have voicemails waiting to be listened to. Does anybody know where i can get this number from.
P.s. - I am on orange.
Is it short code 123 ? (I'm O2 myself but I did a quick search).
You can get all network configuration from Nokia Site. They send to You by SMS the configurations.
Yes I believe that is the correct number for Orange voicemail in the UK. Voicemail number is not a setting you can get from Nokia.
I believe the full number is +447973100123
Thanks guys. All sorted now 😊
hoponhiggo wrote:Hi,Stupidly, before flashing my firmware to the latest V4, i forgot to back up all my contacts to the memory card, thus loosing them. The number for my voicemail box has also dissapeared, and i have voicemails waiting to be listened to. Does anybody know where i can get this number from.
Phone your network operator and ask then the number or shortcode for Voicemail.
You may also find the number stored in your SIM CARD which would not have been cleared by the FW Flash. (Contacts -> Options -> SIM contacts -> SIM Directory)
Here's a couple of numbers I have used myself...
O2 = 901
T-Mobile = +447953622278
Dez 😉
