Syncing Ms Access Databases to 9500?
2 replies · 1,734 views · Started 30 August 2006
since a few days I'm a proud owner of a brand new Communikator 9500!
I have searched the forum but didn't find the right answer: Is there an applikation which allows a real data-sync with MS Access?
SincroNokia enable a synchronization among desktop pc and a Nokia Communicator.The format of database file on Nokia Communicator is Palm type (.pdb) but on desktop pc you can select by file udl which database you want to use (MSAccess ,SqlServer,Oracle, etc..)
Edmond wrote:SincroNokia enable a synchronization among desktop pc and a Nokia Communicator.The format of database file on Nokia Communicator is Palm type (.pdb) but on desktop pc you can select by file udl which database you want to use (MSAccess ,SqlServer,Oracle, etc..)
Thank you for your answer!
Can I open .pdb files on the Communikator?
