Firstly im new here so hello to all
Got a small question
Video messaging it is possible on the t-moble.de website, but im english its in german can anybody help me ??
Since you are new I suggest to use the search option on the top of the screen. This way you will find the information you need!
Hello Hudson
Welcome to the Forum
Can you be a bit more clearer please? You need help with what? The Video messaging software, or the German site?
If u are after the software, you will find it posted (along with the patch for the english translation) in the forum. Just use the search option available at the top of everypage.
And yeah.. you will have to be registered and logged in to see any of the posted files.
Goodluck 😃
PS: Pl try to make the Question as specific as possible, to enable precise responses.
Hey there Hudson.
Welcome to the Forum. You just received your initiation rites. 😃
I just hope that maybe you could freeze the header part of the forums so that those links will always be visible.
Like having them as stickys?
Well then it would take alot of space in front of the forum, and look ugly for all the regular users trying to look for new topics and having to go through 5 stickys or something
Searching only takes about 30 seconds 😊 then you'll find all the info you ever wanted 😉
fall away dunk??? now that's gotta be tough! 😃
What I meant was the part where you could see the "All About Symbian" image... Album..FAQ..Search etc. frames usually do the trick but is there any other way? Don't like frames. 😉
