HELP! 7610 SMS keep re-sending/not sending at all.
2 replies · 1,982 views · Started 31 August 2006
Hey. I desperately need help. Does anyone know how to fix this particular problem aside from sending it back to the manufacturers, as i have done that 5 times. it will be fine sending messages for a wee while then it starts to go onto resend, wherby it sends like three or four, but now it just wont send at all although it says it is infact re-sending in my outbox! HELP ME PLEASE! it's driving me crazy. Thanks!!
Go to Messages->Settings->Text messages->Message center and see if the correct one. If not, ask your operator to tell it to you change it.
