Hi there,
Had a quick search and couldn't find anything on this eleswher, so my apologies if there is!
Just got my 7650 today and its fantastic!! 8), the only problem i'm having, is not with keeping the op logo (orange seem to have been nice to me!!), but whatever I change it to is horribly stretched and out of proportion.
I've only been using images off this site so far and I've checked that they are the 97x25 or whatever pixels. Any ideas for a stupid newbie/ 😃
Could you post a screenshot? you can do those with SeleQ or that PsiLoc program (cant remember the name of it). It would clarify this somewhat :-?
The size should be 97 pixels wide and 25 pixels high.
and its place should be on upper right corner of screen (next to battery level meter) 😃
And I forgot to say, welcome to the forum 😃 😃
Thank you very much for your hospitality! This thing's so good it's got me up till 3am! How Sad! Yup, hope this was what you wanted, its supposed to be a bottle of bud (the same one that's in the gallery).
Thanks for your help! 😊
i think it has something to do with the sort of picture it is.
it has happend to me, some pictures just don't fit as good as others, the one i have now fits quite nicely though
How are u trying to se the logo? manually or with SeleQ?
How very bizarre! With SeleQ if that makes a difference?
well, if u use SeleQ go to the folder where you put the logo in and try to open it and view!! sometimes it was already stretched or after it was placed as a logo !! i had the same problem though! at first i couldn't get any oplogos up and when i got it, it was stretched!! :evil:
well, never found a solution! it pissed me off and i gave it up!!
happened to me before while using seleq to set mu op logo.. just try to do it again and your problem will be solved..or better yet swith off/on ur phone.
aarrgghh..forgot to login again..
[quote="Shadow"]well, if u use SeleQ go to the folder where you put the logo in and try to open it and view!! sometimes it was already stretched or after it was placed as a logo !! i had the same problem though! at first i couldn't get any oplogos up and when i got it, it was stretched!! :evil:
well, never found a solution! it pissed me off and i gave it up!![/quote]
dang it! good thing this has never happend to me. so shadow, you mean you cant use colored logos up to now? dang that's bad news brah! :-?
Success! Thank you for all your help, everyone! I did what was suggested and went into the folder and simply manually placed the picture and all was fine!!
Thanks!
Adrian
Guys, Im having the same prob like yours, the image was fine and i set the image to OpLogo then it was streched out and doesnt seem to fit in, i tried what you guys suggested and the same image fit well, i wasnt contented and change the image again to another, then it was streched out again. i repeatedly do the same in case it will came out fine again but until now, i'm having the streched out logo and can't bring it back anymore! please help guys! i coudnt even bring back my Network opLogo stock back on! 😞 help me guys please. 😞
Can't understand that :-? It worked fine for me. The one thing I might suggest is make sure you are taking the images from the 'images' folder and not the 'images_tn' folder as I think this folder stores the thumbnails for your pictures and this would stretch them. Might be wrong, but that crossed my mind
Adrian
yeah you're right, the images_tn is for thumnails. Is that what's causing the strecth-tasy?
good for you guys, but for me, i can't use any colored operator logo :cry: don't know why! maybe it's my SIM Card !! also tried .mbm but it didn't worked too !! oh well!!
