Hey All
I Am new here , but i got a problem with my nokia 6680 , the problem is when i first bought my mobile this problem did not occure , but now i noticed it is , the problem is when i copy a song or video or a picture to the mmc through the caple using the nokia usb wire that i connect it to the mobile , the problem is after i copy the file and un plugg the device from the usb , i have to open the multimedia card section and wait till it say remove ur mmc then close it , it kinda make a re fresh or something , but i formatted it , still same problem 😞 , when the first times i used it to copy stuff to mmc it did not needed to take off the mmc and return it back , any help pleasE?
Problem With My 6680 please help
Do You have some other SW installed? Could be the cause of that.
nj7 wrote:Do You have some other SW installed? Could be the cause of that.
I didnt understand ?? what do u mean by ''SW'' Sorry i am new here !
Another SW - Software installed, can cause some behavior problems. Usually, the worst one, are the themes...
