Blackberry & Blackberry - E61
8 replies · 5,285 views · Started 01 September 2006
I installed the Blackberry supplied software on my E61, after this I noticed that there are 2 installed "Blackberry" & "Blackberry2", it is using "Blackberry2" anyone else noticed this on there phone? Should I deactivate "BB2" and use "BB" or just remove "BB" and stick with 2... Or does it need both?
I also have both connections, but it doesnt matter which one you use because the module automatically choose which one to use
But if you try to use the bb2 or bb connection to navigate you wont find answer from the server
If you download the bberry 6.28 (1) version that connections dissapears from the access point list.
So should I update my Blackberry installer? When I look in my App. Manager it says "Blackberry" installed this is version 6.18... How do I get the latesrt version?
I noticed that there is also software called intellisync software... Is this better than the Blackberry software for the E61?
I tried to install, it gets to the end and then says "unable to delete file" do I need to disable Blackberry?
tomyknoker wrote:I tried to install, it gets to the end and then says "unable to delete file" do I need to disable Blackberry?
you should uninstall the first version before installing the newer one and you have to off the blackberry service so that the app would not be running if you are installing the newer one version.
Hope that helps
