4.0623.0.41.... Worth updating?
7 replies · 2,620 views · Started 01 September 2006
I am concerning updating my N80 with the new firmware. I just have these questions... If i update, will i lose all my text msgs? What other than the contacts goes lost? I have no apps on the phone itself, only on the memory card.
Any opinions.
Also, will i get the adobe reader by using BB5 Reaper?
move all ur messages to ur memory card, sync ur contacts with ur pc or copy them to your sim card, you can also do a complete backup of your phone before u flash with the nokia pc suite and restore after you flash.
Bricked my n80. It didnt repond at 20% ...
shoulda waited for the offical nokia software updater.
i flashed mine twice, no problems, make sure ur battery is fully charged before you start, and follow instructions EXACTLY.
i heard theres a way to flash bricked phones with the phoeinix 2006, but im not sure, search around fdxd u might be able to bring it back to life.
i followed instructions but i think my firmware was corrupted? or something odd happened? It seemed fine at first then it stopped responding(restart i think). I'll have a look around.
i went through the process, and then when i ran the firmware exe file, i got an error and i couldnt install it... is the firmware hosted anywhere else than on nokia.dogtoe.com?
