How signsis without a .key file?
1 replies · 0 views · Started 01 September 2006
How can I use the .cer file which the symbiansign made for me at a request
for dev cert?
How can I make a key ?
The DevCertTool makes a .cer and .key itself, now how can I signsis without
a .key?
Hi Marjan
I suggest you please go to
https://www.symbiansigned.com/app/page/devcertgeneral and read all the
documents!
DevCertTool can make a .cer and a .key and a .csr (or you can input existing
ones). The .key file is what you use in signsis. The .csr is what you send
to SymbianSigned, and the .cer file can be thrown away.
SymbianSigned give you back a new .cer file ... you use this and the
original .key to do the signing.
Regards
Hamish
"marjan" <[email protected]> wrote in message
news:[email protected]...
> for dev cert?
without
> a .key?
