has anybody changed there n80 in any way using phoenix?
6 replies · 2,956 views · Started 02 September 2006
i noticed there are a lot of tests and settings you can change with phoenix 2006, i was curious if anybody experimented with any of the settings. has anybody "tuned" there n80 with phoenix? if so, please post your results here.
cbcharlie wrote:well i discovered you can change your mac address and serial# with phoenix.
Just a word of warning...
Changing the serial number (IMEI) of a mobile phone handset carries an unlimited fine and up to 4 years prison sentence in the UK (if you are caught...)
Dez 😮
The cracked version of Phoenix only has limited functionality, not all the menu items will work or work properly. At least that was the case with previous versions of Phoenix.
i managed to test functions like screen / vibration / cell signal test / wifi tests and tuning etc...
Nothing really usefull though.
dez_borders wrote:Hi,
Dez 😮
hmmm so you could get a barred phone and change its IMEI and then.....hmmm
well i didnt change my serial and i dont live in the uk anyway ;p
has anybody found a way to test the button lights?
my phoenix errored on testing the gsm signal and screen tests, which version did you use to do that?
