I am not able to transfer the file of size more than 90 MB from the N91 Hard Drive to PC. It gives an error "Operation Failed. The Item is in use." whenever I try to do. Is there a file size limit?
However I could copy the file with size more than 90 MB from PC to N91 Hard Drive but not vice versa!
N91 - Files with size more than 90 MB
If is only one file, could be a corrupt file. It happens also on PC�s. Try with another file to see if is some limitation or that file.
Are you using USB Mss storage? I havetransfered many 180-200 MByte full movies no problem
1) use USB mass srtorage
2) See the thred here where it tells youhow to update you sw at home - I just did it and it was great!
music101
patel_d_l wrote:Hi,
I have copied a single file of 1.3 gb to N91 and again transferred the same to my PC's HD. I had no problems. (Though it takes a long time) This means there is no file-size limitation. All I can say is to defrag your N91 Hdd through PC and not the device itself. Connect your N91 through Mass Storage and select defrag from the PC. I have done this many-a-times and it works fine. You can give it a try.
