N80 V 4.0623.0.41 & iSync
11 replies · 3,253 views · Started 02 September 2006
My iSync stop working after the FW upgrade. Used to work fine before the upgrade.
The phone has "System error" message and the Mac shows
Saturday, September 2, 2006 3:04 PM
[NOKIA N80] Device is not available or synchronization was cancelled. Close dialogs and applications on the phone and try again.
Device "NOKIA N80" synchronization failed
Removing and reinstalling the device doesn't help. Anyone has the same problem?
uninstall nokia connection program and drivers. On windiws running CCcleaner does alot of good.
kf6oyk wrote:My iSync stop working after the FW upgrade. Used to work fine before the upgrade.
It did same thing on my first flash. Because i never selected anything in the code box in pheonix. Refliahed again this time choose Euro pearl black and sync up nicely.
I use the plugin from novamedia.de for iSync. Apple iSync has no native support for N80 of course. When I upgraded from v 3 to 4 on my phone, I had no problems at all. It worked immidiately. Only that this time, there was no bluetooth bug, so there were no interruptions while transmitting the contact info. Nice!
Had the same sync issue.
Formatting with *#7370# solved the problem and my N80 works again with iSync. (Don't forget to back up!)
pwy wrote:Had the same sync issue.
Just to confirm... you're using the v4 firmware? Which version of iSync are you using (or, which version of OS X are you using)? Are you using the novomedia plugin?
I'd hate to get the thing flashed to v4 and then find I can't use iSync.
Regards
SL
Worked for me.
Your a star! Thanks :icon14:
In the same situation with no sync and willing to hard format the phone after V4 apgrade but do you mean back up with the phoenix? as without sync working there isn't any other way is it? thanks
satello wrote:In the same situation with no sync and willing to hard format the phone after V4 apgrade but do you mean back up with the phoenix? as without sync working there isn't any other way is it? thanks
You can backup phone memory to (and restore from) the memory card.
hi thanks for the hint... I browsed all my phone but could not find any app that could do backup. is this from a 3rd party or does it comes with the phone? your help is much appreciated.
Thanks pwy for your helpful and informative post.
Cool that you managed to flash your N80 from your Mac! 😎
Cheers
SL
