music player playlist
2 replies · 2,276 views · Started 03 September 2006
sounds like a really stupid question but how do i make a play list in the music player. Ive tried but i cannot add songs properly and remove songs. Also can a play list be made via a PC.
Many thanks.
You can bring over a standard playlist from your pc. (Not sure which formats are compatible but winamp certainly is).
Alternatively within the phone it's known as a tracklist. Options, add to tracklist and it should be self explanatory from then.
GO Music Player ---> option ---> music library ---> track lists ---> option ---> new track list ---> choose ( phone memory / memory card ) ---> track list name ---> then mark the tracks you want to add to the track list ---> option ---> select marked items ---> option ---> play ( your track list )
and if you want to add/remove track(s) from your track list go :Music Player ---> option ---> music library ---> track lists ---> option ---> open your track list ---> option ---> add tracks ( or mark the tracks you want to remove from track list ---> option ---> remove from track list )
cheers
