is it the apps or the service provider
4 replies · 1,948 views · Started 04 September 2006
i got a n70 with vodafone ausrealia pre pay sim......now i want to use turbo msn i got 1.0 ver will not sign in just times out
and also i got netfront 3.2 will not do anything
is it the verson of the apps or is is that i am vodafone pre pay??????
also what version of these apps should i run?????
There are some issue that u can d/l or install app except from vodafone. Try to contact them for sure.
you need a GPRS connection to work your turbo msn, on WAP connection it doesn't work.
GPRS connection and settings is fron your network operator...
rulirahm wrote:There are some issue that u can d/l or install app except from vodafone. Try to contact them for sure.
well i can install it but it wont connect
mad.rottwailer wrote:you need a GPRS connection to work your turbo msn, on WAP connection it doesn't work.
ohh cool that good as thx
