E61:FW version 1.0610.04.04 to version 2.0618.06.05 improvements
6 replies · 6,283 views · Started 04 September 2006
Changes/improvements made from MCU SW version 1.0610.04.04 to version
2.0618.06.05:
- Active Idle:
- Active standby mailbox settings moved from
Messaging/Options/Settings/Other to Tools/Settings/Phone/Standby
mode
- Missing texts added to Active standby mailbox settings
- Active standby mailbox setting is now included in backup and restore
- Application installer:
- Not possible to launch some downloaded game.
- Email:
- Sound (or vibration) alert is added to Blackberry email)
- Calendar / PIM:
- Improvements to exception handling in recurring calendar notes.
- Improvements to end times handling with Calendar Memos.
- Support to RTF files added to Notepad.
- E61 keyboard support improved in Calculator for calculator Operands
for languages where supports was missing
[SIZE="4"]- Contacts:[/SIZE]
- Changing the order of <Last name> <First name> order corrected are
in Malaysia language.
- Large vCard which received by IrDA can not be saved or deleted.
- Possibility to set Unprotected 3gpp2 and wma audio files contact's
ringing tone removed
[SIZE="4"]- Office tools: [/SIZE]
- Sheet, Presentation and Documents mixed localisation improved to
English only
[SIZE="4"]- Device Management: [/SIZE]
- Beep added to DM Server connection request Notification
- Application installation improved in first connection to DM server
- Policy handling improved in first connection to DM server
- Synchronisation
- Increased robustness of recurring event synchronisation
- Synchronisation overall reliability extended
- Added support for larger data amounts
- Synchronisation fails if entering more than 2 entries in Calendar of the
handset with synchronisation setting as "None".
- Added support for synchronisation while device is locked
- Device specific suspend-resume functionality added
[SIZE="4"]- Backup & restore [/SIZE]
- Improvements to overall reliability and performance
- The backup function of PC Suite can not be used when the data folder
of the UE registered files to be full.
[SIZE="4"]- DRM: [/SIZE]- CFM protected files do not show the correct icon in the gallery.
- No icon is displayed next to DRM FL files to indicate DRM protection.
- E61 does not support ring tone=no eCFM flag.
[SIZE="4"]- RealPlayer: [/SIZE]
- Streaming maximum bandwidth increased in EGPRS from 65.28 kbps
to 84.42 kbps and in WLAN from 268.80 kbps to 1 Mbps
[SIZE="4"]- Audio: [/SIZE]
- Audio quality improvements
[SIZE="4"]- Java: [/SIZE]- Performance improvements.
- Ram consumption reduced.
- Canvas graphics scaling faster.
- Midlets installation and launching:
- �!� (Exclamation mark) can be handled in URL.
- Midlets installing and launching process is more stable.
[SIZE="4"]- MMAPI improvements: [/SIZE]
- TempoControl.setTempo(int) now returns correct value.
- Audio and video works more stable/smooth during real time streaming.
- Hebrew strings are not mirrored in Forms.
- Cannot run the midlet from CMCC Java server.
[SIZE="4"]- SIM: [/SIZE]
- It is no longer possible to changes line when there is no ALS support in SIM.
- Improvement in Dual IMSI SIM handling.
- SIM ATK:
- Automatic and manual IMSI change with SIM ATK is supported, and
SMSC number is automatically updated to text message settings
- Improvement to SIM toolkit command "SEND USSD.
[SIZE="4"]- Web Browser: [/SIZE]
- Improvement to pull-down lists, Browser is crashed when pressing
"Select" key repeatedly during the display of pull-down list.
- Improvement to security icon functionality, There is a discrepancy on
the states of the handset upon cancelling the moving process from
http:// to https://
- Improvement to browser Tel URI support
- Services (WAP Browser):
- Improvement to receiving multiple Push messages.
[SIZE="4"]- MMS: [/SIZE]
- Improved MMS handling when active BlackBerry connection.
[SIZE="4"]- Telephony: [/SIZE]
- Improvement to always on Email connections in situations where PDA
shut off by low battery
- Home Zone indication not anymore shown during active 3G PS
connection/download
- Improved context activation time in PS dialup (based on the PPP
handshaking with MS Windows)
- Improvement to sending USSD short codes after the USSD menu has
- timed-out
- Always On functionality added for H3G
I have been told by '3' that if any firmware update is performed it will be outside of my subscription with them and all further handheld support may be void.
Marky
Atlas Communications in Glasgow just told me that they have the 2.0618.06.05 firmware, and that it can be updated (by them) under the Nokia warranty.
Yay!
markrich wrote:I have been told by '3' that if any firmware update is performed it will be outside of my subscription with them and all further handheld support may be void.
Marky
Who told you that? If it is the actual company policy, then it's a very sad situation.
Do you think they meant that they'd cut you off their network or just not support the phone if it broke down?
When can we get this new firmware......the E61 isn't listed on the software upgrade page.
BTW...Has it fixed the IMAP idle issue?
Cheers
Ventmore
TANKERx wrote:Hi,
Well it does make some sense. Afterall, the 'free' phone is subsidised by '3' and you return a lot of the cost in the monthly subscription. Until the subscription period is ended they continue to provide free support based on the model which they supplied to you. Change that model signifficantly without their agreement and I guess they have a right to refuse future handheld support. Afterall, they won't have information which can say what problems - incidental or deliberate - those modifications have created.
I remember working for some while for a computer games support line. If someone called up with a problem with their game and during the conversation it transpired that they had added 'mods' not created by the company, the only thing that could be suggested was, "remove the mod as we can't support the game changed in violation of the licence agreement in the box".
My fingers are crossed that '3' offer this new firmware as a official upgrade soon to retain the support that I may be called upon to use. The official Nokia service centre here in Bristol is Carphonewarehouse and their shop is just around the corner from the '3' one so hopefully it'll be cleared by '3' soon and then I can go get my bugs fixed. 😊
Btw...does anyone know if the upgrade makes the phone a little snappier in it's use? The present OS is very sluggish.
Marky
