I have a nokia N70 and am trying to sync with outlook2003, I have installed Nokia pc suite & using the sync function, i can get the phone contacts to download to oulook, but i can't get the oulook calender etc, to sync with the phone. It just terminates the sync process.
Please help! 😊
Do you have anniversaries ? I have seen that sometimes anniversaries in Outlook can cause calendar sync problems ?
Do you sync contacts separately from calendar (it seems so). Have you create fresh new sync settings in PC Suite when you started calendar sync ? Do you have update both directions in use ?
