Delete SIP Settings
2 replies · 6,281 views · Started 04 September 2006
Like so many others, I tried setting up SIP Settings convinced the N80 should be able to do VOIP out of the box.
Now I've done it, hasn't worked, but I can't delete them, or edit them, or add any more!
Im going to Tools > Settings > Connection > SIP Settings
(now my phone just crashed on me)
But I've Tried Options > Delete > Do you want to Delete? Yes! Doesn't delete.
Options > Edit
Nothing
Options > Add New > Use Default Profile
nothing
Options > Add New> Use and Existing Profile
crashes back to tools menu
V 3.0617.0.6
03-05-2006
RM-92
Nokia N80 (31.01)
Any Thoughts?
Simon
While setting up SIP (for the same reason, I might add) that happend to me too but I solved it by just resetting the phone.
As you're on the older firmware have you considered getting it flashed to a newer version? I can delete SIP settings fine on v4, but as well as that you'll probably find that the settings will be wiped in the upgrade anyway
