9500: Other wallet software beside HandySafe?
3 replies · 2,339 views · Started 04 September 2006
is there another good wallet software beside HandySafe which can sync data with desktop?
The problem is i would like to use HandySafe but it seems Epocware/Paragon has no support!
I tried to contact them through their web-form but submitting doesn't work.
Sending an email results in an autoresponse which tells that there is no support through email!
What happend???
I believe Handy Safe is the only one with PC syncing ability 😞
Sorry, not what you're looking for, but a mere confirmation. I hope I'm mistaken though.
My experience with purchasing software for my 9300 is --unfortunately-- to go through the trial period, and if it works for me I just purchase it with the expectation that there is no support, and if I need any and got some along the line, I'll be happy. I know it should be the other way around, but that's the sad truth (at least with the developers I dealt with).
Good luck...
