Restore N73
1 replies · 3,314 views · Started 04 September 2006
Just purchased N73 and would like to restore my contacts from my Nokia 9300backup. I tried to change name to N73 without luck.
Any help will be appreciated.
Have you tried the Transfer on the phone?
Or sending the business cards via bluetooth / IRDA?
Other thing is a program called Contacts Manager, this saves your files as a CSV, then you can use Contacts Manager on the n73 and save the CSV into contacts.
