my phone can only fill with few video files. is to possible to reduce size of video file? any appl? thks in advance.
video file suppress software?
i dont know any professional appl to reduce size of video files. i usually do it with my video converter. i can cut 3/4 off with lowest bit rate. (32 kbps) . i use xilisoft video converter 3.1. u may have a try.
evanstar wrote:i dont know any professional appl to reduce size of video files. i usually do it with my video converter. i can cut 3/4 off with lowest bit rate. (32 kbps) . i use xilisoft video converter 3.1. u may have a try.
Thats the way to reduce... low resolution, few fps, less detail!
