hi all,
I have Nokia N72. I installed a Spiderman by Babi and P@sco theme. I tried to uninstall, it gives an error and says unable to complete.
If anybody could give steps how to uninstall manually that would be of great help.
I have FExplorer and TaskSpy installed.
Thanks.
With FExplorer, delete the folder on E:\System\apps
If you do this, you'll loose all your apps which are installed in the phone. If you want to delete the skins, you need to delete C:\System\Skins
ratza wrote:If you do this, you'll loose all your apps which are installed in the phone. If you want to delete the skins, you need to delete C:\System\Skins
C/System/Skins/the theme you want to delete(it will be a number so open that file and the name of the theme will be in there),If they are applied to phone memory.
E/System/Skins/the theme you want to delete(it will be a number so open that file and the name of the theme will be in there),If they are applied to the mmc.
Dont delete the whole folder or every theme will be deleted!!!!!
Is to delete the folder ON, not the folder apps😉
