problem with clock
3 replies · 2,160 views · Started 05 December 2002
i have a problem with my clock
it always go back one hour
i have set the auto time update to off
and this appears when i run world clock pro AND \ OR handy clock
to set a new alarm
is there is any setting for that ?
please help
Do you sync with your laptop or computer? maybe there's a delay in your pc's clock and when you sync the 7650's clock gets adjusted the way your pc is. (been posted before, and that was the solution. There was another thread also when this didn't work, try a search 😉)
done at last
my computer clock was not set to gmt
i set it to gmt and it now working fine
thanks alot
:angel:
